Wifi adapter for 722
Do I then just use a usb hub to connect my EHD and the adapter to my 722?
Maybe. I've heard some guys have tried a hub, or usb splitter and it doesn't work having 2 things hooked up to the usb port on the back. I have a cheap usb splitter I paid $9 for at walmart (Targus brand) and have my EHD and Sling Adapter hooked together into it, and it works great. You can try a usb hub, and if it doesn't work, you'll have to plug one of items into the front usb port and have the front door open, which kinda sucks...
Maybe. I've heard some guys have tried a hub, or usb splitter and it doesn't work having 2 things hooked up to the usb port on the back. . .
I would imagine that this might be true if a USB hub acts like a Ethernet "Switch" and not a "Hub". Hub where all connections are interactive all at once. A Switch where one device connects only to another leaving others locked out. Or two others while the two are. So two and two - 4. Not three. Which is what would be needed here.
error 015 and 0 signal strength
Strange remote control mal-function problem
