Why few C band sats in Pansat 2700a?
Corrado
2,428
303
Hudson Valley Region, NY
I've noticed my Pansat 2700a doesn't have many C band sats in it's memory. My former Fortec Lifetime Ultra had many, but with the old satellite identification. It's difficult to add for some reason to the 2700. When attempting to blindscan it always wants to search Ku frequencies. I end up manually adding TPs, SRs etc. from my data I have accumulated over the years.
I've noticed that too. Since I don't have a C-Band dish installed (yet :) ), it hasn't been an issue for me. What you can do is edit the satellites that are on the other side of the globe from us to add the C-Band sides for your satellites.
You can add as many sats as you would like ... It's an exercise of your thumb though, especially when adding the name of the sat. You can do this at what I believe is the first menu of the installation screen toward the bottom.
converting transponder filename xxxx.ini to degrees
Two satellites on one LNBF?
