Where'd the Technical Forum Go?
I think it will work better this way once everyone gets used to it.
I agree that it is a good change, alot of times I forgot to check the tech forum, and there is lots in that area I could help with.
None of the threads went away, they were all moved to this main forum.
I'm glad it was merged as well, I did look in it regularly and posted as well, however in some cases you may have a situation where you don't know which forum to put you issue in, the regular forum or the Tech side.
As others have mentioned, it didn't get viewed quite as much, I think the major posters in the D* section did reply in it, it will still make it easier this way.
One problem was when someone would start a thread stating the same thing in both sides, people would reply in one and the poster wouldn't see the reply because they were looking in the other location.
Satellite alignment problem
didn't want to do it
