OK!, I admit I’m greedy, I wanna see all I can on FTA, but I’m a little confused about where the line is, between getting Circular Signals and actually crossing the line to what’s called “Hacking”!
A learned acquaintance of mine offered:
“All you need is a DBS LNB and a Diseqc switch to combine the KU band and the DBS into one cable line”. and
“Hacking is downloaded illegal software into a FTA box to override the scrambling technique, thus getting PPV, movie channels, etc for free”.
Given that I have a Traxis DBS1500 and a Spitfire Mod ASC321 LNB, I presume he thought I would dual mount an additional LNB next to the Spitfire.
I’m not sure if I want to do that, with my experience, getting just one LNB lined up will be a problem. But if I were to select (for Instance) a Invacom SNH-031 (just interested in one Receiver at this time) would I then be able to receive both CP and LP?
Then, CP to what extent?
So if I avoid the “Movie Channels”, the rest of it (except for etc) is ok? And, how does one know/tell, if some software is illegal?
I read on the Prosat Com website, where it clearly stated that their LNB (a QPH-031) provides reception for Dish Network and DirectTV! So am I to assume, all I need is that Quad LNB, to get those programs, and if I do, what’s the difference in that, from hacking!? Or is that one of those deals where you can buy that type LNB, BUT, if you use it, it’s illegal?
My Receiver clearly states, it’s “DBS”, I guess it must then be capable of receiving DBS signals! Sounds like you’re hacking, if you did it by accidentally choosing certain components!
I also read somewhere, if you have an older Receiver, you can get programs that a newer receiver can’t. Is that ok?, is that hacking? Maybe I’ll look around the Pawn Shops, no telling what I may find! (Haven’t found SiFi, NGC, Hist, Spike on FTA, yet) I don’t want to give those programs up, when I get rid of my Cable connection! BUT, are they available “ANYWHERE” on FTA, CP or LP?
Therein lies that “line” which (we shouldn’t) cross, but, just how fine, and where is that line?
And by the way, If “somebody” doesn’t like this topic, and chooses to delete this Post, PLEASE just tell me it’s “taboo”, privately if you like, and I’ll get off the topic, immediately, ok! I just need to know up front, if I can ask these type questions.
