4:1:1 - The component digital video format with one Cb sample and one Cr sample for every four Y samples. 4:1 horizontal downsampling with no vertical downsampling. Chroma is sampled on every line, but only for every four luma pixels (i.e., 1 pixel in a 1 x 4 grid). This amounts to a subsampling of chroma by a factor of two compared to luma (and by a factor of four for a single Cb or Cr component). DVD uses 4:2:0 sampling, not 4:1:1 sampling.
4:2:0 - The component digital video format used by DVD, where there is one Cb sample and one Cr sample for every four Y samples (i.e., 1 pixel in a 2 x 2 grid). 2:1 horizontal downsampling and 2:1 vertical downsampling. Cb and Cr are sampled on every other line, in between the scan lines, with one set of chroma samples for each two luma samples on a line. This amounts to a subsampling of chroma by a factor of two compared to luma (and by a factor of four for a single Cb or Cr component).
4:2:2 - The component digital video format commonly used for studio recordings, where there is one Cb sample and one Cr sample for every two Y samples (i.e., 1 pixel in a 1 x 2 grid). 2:1 horizontal downsampling with no vertical downsampling. This allocates the same number of samples to the chroma signal as to the luma signal. The input to MPEG-2 encoders used for DVD is typically in 4:2:2 format, but the video is subsampled to 4:2:0 before being encoded and stored.
4:4:4 - A component digital video format for high-end studio recordings, where Y, Cb, and Cr are sampled equally.
