I was wondering if there are or will be HD for channels like CBS and WB so I can watch Smallville and CSI in HD.
BFG said:The WB and CBS are already in HD....
You need to get an antenna so you can watch them though, which is a pretty simple task if you're not in a rural area![]()
whicky1978 said:I was wondering if there are or will be HD for channels like CBS and WB so I can watch Smallville and CSI in HD.![]()
BFG said:Since the only channel you get in 720p is ESPNHD you really should set your 811 to 1080i, because when the 811 is set to 720p it downscales 180i to 720p using it's scaler which is a POS, letting your TV do the scalling will yield much better results?
If you really want CBS and WB there are ways to get the signal directly from the network but it requires a C-band dish, a satellite pc card and a powerful pc, I only bring this up because usually rural folks have c-band dishes lying around![]()
