After reading Jeff's post about the Manhattan last week I am unsure if I will ever see a fix for my situation. My setup is not that complex, just a 8 food C/KU band dish with a WSI 721 LNB.
The 721 LNB uses 22 KHz switching. In motorized mode the Manhattan does not control the 22 Khz switch.
I also have a BSC-621-2 which uses DISEQC 1.0 switching. as Jeff said they are planning on supporting 1.1 switching on the Manhattan but not 1.0.
So because of my setup with both of these LNB's I can fully use them with my Manhattan.
I would rather keep using the WSI 721 as both my C Band and KU band signal levels are much better then the BSC-621. So it is my understanding that the OpenBox and works well with both of these LNB's.
So my question now is which is better the OpenBox S9 or the Openbox S10? I dont really care about the clock (since it doesnt work anyways) is there anything else missing from the S10 over the S9?
I am thinking about going with the S9 but since the S10 is newer maybe its better?
Whats your thoughts guys.
Thanks!
Thanks!
