Ok, what I have now is a "Tracking" dome covered dish with an older 211 receiver. Works fine, only issue is that I can only get one sat (110 or 119) at a time, by design, and literature says no HD, and my model is to old to "upgrade". I also have an unused, crank-up dish on the roof that is unused.
Here is what I want to do:
I want to retain the Tracking dish as this works while driving down the road. This is fine and the cost of upgrading to a dome that receives HD is cost prohibitive. But, I would like to retrofit my crank-up to a dish 1000. The Tracker is legacy. I want to retrofit so I can get HD channels, etc while parked. I checked the mounting brackets comparing to my home dish 1000 and the specs are either the same or so close the retrofit will be easy, as will the LNB.
So after I do this retrofit, I will end up with 2 cables coming down to go into my receiver, with one (The retrofit) needing to be split to use with the newer receivers. (Yes, I will be upgrading that as well).
So the question:
What can I do, short of unscrewing and reconnecting cables, to facilitate the changeover from one dish to another? Is a A/B style switch capable of doing this? My RV does have a high quality switch that is used to switch between inputs to the TV, which I could use to switch between dishes to the IRD. Any thoughts? Possible?
So the question:
