Was wondering what brand of projector would be best for an X-box 360 setup. MUST be reasonably priced though.....Thanks
Why would you need a projector? (Assuming you are talking about a front projector.) Regular big-screen RPTV or a flat-screen TV might work better for your budget and room size, I suspect.
With 9' distance you'll need a projector with good zoom....up to 1200.00
...haven't got a screen yet (have about 9ft. from wall to wall)
was looking at dlp lcd,bout the same price,maybei did a setup for a friend...he was at 7 feet and we installed a 65" front projector Panny 900. It looked awesome for the first 300-400 hours...then it developed green blobs.
If you chose LCD be very aware of panel degradation. Chose DLP if you can.
Gregg
I would highly recommend the Panasonic PT-AX200U.
Panasonic PT-AX200U Projector
720P
Brightness: 2000 lumens
Contrast: 6000:1
$1299
That Panny is made for gamers. While Panasonic usually boasts about hollywood producers helping them do the color depth and correction, their push this year with the AX200 is all about gaming and no lag. At CEDIA they had some gamer champ on hand that helped them tweat the AX200 to optimize it for gaming.
If that's what you will use it for the most then it should be your #1 choice.
DD
