With that particular recvr, you can go either way ... SWM (and a PI) is the way I would go as its set up for future recvrs.Thank you for your response. I have one cable.
The story is this: My property was a hit by lightning and fried the old style receiver thus the H24 replacement. The old setup had the SL5 PIG-Z LNB and B-Band converter.
I replaced the RG6 and tried both the b band and H24 to no avail. Methinks I now need to get a new LNB.
SO: Must I use the same exact LNB ? What should or can I use? Can you tell I'm new to this?? Taking a crash course here!
MJ
Or you can use the other option without the PI and use the Slimline set up (one with 4 cables and a BBC )
Is this the ONLY recvr in the set up ?
There are multiple SWM LNBs out there, any of them will work ... so to answer the question, No.Yes, only one receiver and one TV as it is a summer home.
SO: Must I use the same exact LNB ? This is the part I don't understand. Since I have both the power inserter and the b band converter I should be covered right? My suspicion is the LNB is damaged and I must replace it.
Yes.So this Slimline SL3 will work and I would use it with the Inserter P121R1-03 SWM ODU Only ?
That one will work, too. It also requires a power inserter. Either 21 or 29 volt model is fine.Thank you Jimbo, you have been very helpful.
I can get this one by tomorrow.....this will work as well right?
Amazon product ASIN B01AIOOLH0
Thanks Chip,That one will work, too. It also requires a power inserter. Either 21 or 29 volt model is fine.
I figured you were busy, you haven't posted all day. That's not like you!Thanks Chip,
Been a long few days, just got on today.
Work does call .... lolI figured you were busy, you haven't posted all day. That's not like you!
Thats what most of us are here for ...Gentlemen,
This was quite a journey! The new LNB worked and a suspicious cable was replaced as well. Your help was greatly appreciated... I needed direction/confirmation/confidence to get it done.
Thank you so much!
