What is the 522 tv2 RF output?
WakeBdr
SatelliteGuys Guru
138
Cumming, GA
Is the 522's RF tv 2 output analog or digital? I'd like to combine it with my OTA signal from my antenna and watch it on my ATSC digital tuner, but it doesn't see the signal. I'm assuming since it can't tune it in, that it's analog.
Anyone know for sure?
make shore yore 522 out put tv 2 is on off air antenna then use 2 way splitter to combined them together make shore there is a couple of channels separation between tv 2 out put and antenna so they wont (bleed in to each other) inter fear with each other.
Remember, TV2 output will not be channel 3 or 4, but rather a channel you set in a much higher channel number range (i.e., 21-69). And it also provides MTS stereo audio on that channel. :smug
Superdish 121 + Dish Pro Plus
Mysterious Problem!!!!!!!!!!!!!
