What is a good material for an antenna?
Why are outdoor antennas made of aluminum? Why does it matter that antennas like Winegard’s Flatwave have elements made of silver between two pieces of plastic? Is there really that much of a difference? You may be asking yourself these same questions, so let’s talk about good materials for antennas.
The purpose of an antenna is to conduct electricity, because radio waves are a form of electricity. So, one thing that we know an antenna must have is conductivity. Conductivity is a measure of how well any material conducts electricity. Materials that do a really bad job of conducting electricity, like rubber, are called insulators. Insulators are needed because otherwise we couldn’t touch anything electric. (It turns out that our skin makes a pretty good conductor; anyone who’s gotten a shock knows that.)
Part 1: A conductive material​
It’s probably pretty obvious that most metals are good conductors, because any time you see some sort of wire it’s always made of metal. Connections between parts in a computer are gold, and wires are made of copper. Not every metal conducts electricity equally. Let’s take a look at some common metals in order of their ability to conduct electricity. The top item on the list is the most conductive.
  1. Silver
  2. Copper
  3. Annealed copper
  4. Gold
  5. Aluminium
  6. Calcium
  7. Tungsten
  8. Zinc
  9. Nickel
  10. Iron
Silver is the most conductive, meaning that it’s going to do the best job pulling electricity out of the air. Copper, that favorite of wire makers everywhere, is close to the top of the list. Iron, used in cheap indoor antennas, is near the bottom of this list but still does a passable job.
Part 2: A material that resists oxidation​
Silver is the ideal material for an antenna like the Flatwave because its silver elements are encased in plastic. However, an outdoor antenna made of silver would be a disaster. Oxidation is what happens when a pure metal hits the open air. Iron turns into iron oxide, which we call rust. Copper turns into copper oxide, which is that green stuff on the outside of the Statue of Liberty. Most metals are prone to oxidation in some form or another. Oxidation affects the conductivity of a metal, so a material that oxidizes easily is a bad choice for an antenna if it’s in open air. Some oxides are fairly stable, like aluminum oxide; it forms a thin dull layer over aluminum that doesn’t really hurt conductivity very much. Plain iron, as we all know, oxidizes poorly. An untreated piece of iron will rust out quickly. Steel, which mixes iron with carbon, does not oxidize as easily. Gold hardly oxidizes at all.
Judging solely on oxidation, the best material for an antenna would be gold or stainless steel. Of course, this leads us to part 3…
Part 3: Cost and structural integrity​
For an indoor antenna, structural integrity isn’t important… you hope a 50mph wind doesn’t ever blow through the house. The plastic surrounding the Flatwave is good enough. For outside, you need something that won’t bend too much in the wind, and ideally you want something light enough that if it does fall, it won’t tear a hole in your roof.
Gold may be a decent conductor and great at resisting oxidation, but it’s way too expensive to build an antenna with. It’s also fairly soft and would bend over in a stiff breeze. Copper and brass are also fairly soft and oxidize easily. Iron is cheap and holds up well, but it’s heavy and it’s a poor conductor.
Looking at outdoor antennas, it’s easy to see why the combination of light weight, strength, conductivity and the way it oxidizes make it perfect. Indoor, the best choice is silver, as long as you can keep it out of the air and use something to hold it up. This wasn’t possible in the past, which is why older antennas were made of iron or brass. In the end, aluminum wins out and it’s the material of choice for almost every antenna.
Get the right antenna from Solid Signal​
You won’t find a better selection of antennas than you’ll find when you shop at Solid Signal. If you need help choosing an antenna, call the experts at 888-233-7563. You’ll talk to a real, trained antenna technician who will review all the details and help you choose the right antenna and accessories for you. They’ll even take the order over the phone if you would like. Get the service you deserve! Call us, or if it’s after hours, fill out the form below.
The post What is a good material for an antenna? appeared first on The Solid Signal Blog.
Continue reading...
S
THROWBACK THURSDAY: Lucille Ball
STREAMING SATURDAY: How will generative AI affect streaming?
Who Read This Thread (Total Members: 9)
