What is a DSR Companion Box?
Jim "Spot" Beam
96
Southern Ohio
You are bidding on a brand new DSR Companion Box Receive System.
Specifications:
Voltage; 85 to 264 VAC
Frequency: 47-440 Hz
Power: 15 Watts
RF
Frequency: 950 to 1550 MHz
Signal level: - 65 to - 25 dBm
Impedance: 75 Ohm
Noise Figure: 9dB
Insertion gain: 0 dB
IIP3: +10dBm
Model is possibly DSR-4400
Right clicked on image to save and the DSR4400 was in the file name.
Looks like it is a DCII decoder perhaps. Links from google showed them in use by educational systems.
A little leary of just buying a DCII without knowing I can do something with it.
Anyone have one of these or know if they can be used?
The seller has 98 and has sold none since 9/06.
these are rack units right
don't they work on one channel and you use a bunch together
i think these are units used by cable co.'s ect
i was thinking someone here already has one , maybe they will jump in
Question about motor and gear box
Is it possible...
