What does Dish do if you want locals, from sat 105, and German, from sat 121?
Do you just have to choose one or the other?
GERMANBFG said:most of the internationals are also available on either 148 or 61.5
what's the intl package you want?
Yes, I had thought of that, but I was not sure if, they were going to put the German and other int. channels on 105. now they have the new sat. at 105.justalurker said:Two Superdishes and a DP44 comes to mind. E* has not yet released their single satellite dish for 105 and 121.
BTW: BFG ... both of the German package channels are 121 only. There are quite a few international channel packages that are not available on 61.5/148 or incomplete unless one has a SuperDish 121.
JL
Thanks..... That's what I was afraid of. Too many Superdishes. I really wish that they would just put all the int. channels on 105.webbydude said:I've done several 121/105 SD combos. Generally speaking, the customer has to pay for the 2nd SD. Usually $199. The DP+44 may not be the only way, but it is certainly the best way to do this sort of set up
The dish would be for 105 *or* 121, not both at the same time. It has been rumored since January as an option for those who need a SuperDish but don't want to replace a working Dish500 setup ... or for those who wanted just 121 for internationals or needed 105 and 121.mustang65 said:Is e* making a dish just for the 105 and 121 birds? I hadn't heard that.
umm... Bell Expressvu doesn't use FSS. Are you sure you don't mean Star Choice?JPointerWI said:Dish has been making FSS LNB's in the standard D shape to fit Dish 500 style dishes for a while now . . . . but only available in Canada for ExpressVu customers. One of the main satellites used up there is an FSS. I believe the dish itself is a 30" version of the Dish500, ie about 8" larger.
JPointerWI said:that explains why those LNBF's are almost impossible to find. oh well, it was a nice thought. The other problem with that LNB is that it would be a legacy LNB, which would mean the whole system would have to be legacy, probably using a SW64/SW21 setup, not exactly a simple setup.
