Had the 811 and HD pak for 6 months now but just recently put up a decent OTA antenna with rotor and amp. After spending 2 days turning that antenna every which way and doing "scan for digital"s, I've come up with 2 channels that lock in (70-85%) and seem to work fine. However they're both PBS and seem to run the exact same programs. Very nice byt redundant.
During all that scanning I also came up with a couple of stations that would not lock. I tried to narrow the antenna position for the best signal but the best I could get was 49%. If I leave it alone, the meter kind of bouncing between 0 and then anywhere from 40 to 56% for a second and then either stop on 49% 0%. Seems kind of weird that both these stations would act the same way and both end up at 49%, especially since they're at completely different locations. Since they don't lock, I can't try some of the "view button" tricks I've seen recommended in the old 811 threads.
Is this an 811 bug or just that I can't receive these signals and probably won't even with another receiver ?
Specifically, I'm in central Vermont (05033), right on NH border at 700 feet with views to South and East.
The 2 PBS stations I do get are 24 (Vt PBS 23.1 thru 24.5) and 48 (NH PBS 11.1 & 11.2). The 2 stations that act like they're "trying" to come in are at 42 and 59.
Also, these 2 stations I can't quite get right now, will I likely get them later if they up the power ? I don't think I could go much higher with my antenna.
Thanks,
WaltinVt
Thanks,
WaltinVt
