A while back, I was asked to do some cell signal readings at a very remote location. I’m talking 7 miles away from the closest highway, and a mile from the closest road of any kind. To make matters worse, it was at the bottom of several hills which effectively blocked all cell signals from coming in. It was like being in your own little world where it was still 1985 and no one had cell phones or internet. In a lot of ways, it was kind of peaceful. Still, I could see where it could be a little annoying.
The people there wanted to get cell phone service. Why wouldn’t they? So I set about determining if they could get any cell signal at all. Armed with a Wilson Pro 5G Network Scanner, I took detailed readings. The results were about what I expected. One carrier (not the one I use) had very weak signals, and that was it. As soon as I went indoor I didn’t even get that.
The answer to that, unfortunately, is “no.” A cell phone signal booster can do some amazing things, but it can’t amplify a signal that isn’t there. So, armed with that knowledge, I laid out the other options.
The first and simplest option would be to try to get a cell signal. Generally this means going up high to avoid whatever’s blocking the signal. In this case it would mean going up almost as high as the hills surrounding my location. You don’t need to go all the way up (although you should if you can.) You just need to go up high enough to get one bar or -100dBm RSRP if you’re measuring precisely. Once you do that, the cell booster can take over. Without any obstructions, a cell signal can travel up to 10 miles and that would work in a case like this.
The other option would be some sort of satellite internet and your phone’s Wi-Fi calling feature. This is not going to be the best option since satellite internet is a little weird when it comes to phone calls. The relatively high latency of the connection can mean that things sound a little weird, but it truly is better than nothing.
In a case like this you have the option of choosing traditional satellite internet like Viasat which is reliable and stable, or something like Starlink which is kind of sexy but it’s still very new and that could end up biting you later. It’s really up to you as far as what you feel is the best option.
If you’re looking for a way to connect when you’re far, far off the beaten path, you’ll want to work with someone who can lay out all the options for you. That means working with Signal Connect. We have over 20 years’ experience providing communication solutions to people in out-of-the-way places. Whether it’s a vehicle, boat, or just a remote area, we’ll help you choose the solution that makes the best sense for you. Call us at 888-233-7563 during East Coast business hours. If it’s after hours, no problem! Fill out the form below and we’ll get back to you quickly!
The post What are your options if you have no cell signal at all? appeared first on The Solid Signal Blog.
Continue reading...
Can you use a cell phone signal booster if there’s truly no signal?
Option 1: A cell phone booster on a tall tower
Option 2: Satellite internet
The most important decision you’ll make
Continue reading...
