I'm a curious person, and so I'm wondering, what all technically does "Check Switch" do? Seem's like a strange name for such a mysterious function.
A Check Switch Test is a diagnostic tool used to identify the satellite
orbital slots the dish is pointed to and verify which devices are used in the install. First, the test will
identify the devices installed by sending a command from the receiver, a 22kHz “ping”, to other DiSEqC
devices in the installation. Any DiSEqC devices connected will identify themselves so that the receiver
knows what equipment is installed. After the “ping”, a series of checks are run to determine both polarity
and orbital locations. The receiver will check 4 transponders from each orbital slot. The transponders
checked will vary depending on which slots the receiver is connected to. This information is used to build
a matrix, which the receiver uses to determine what information will be loaded in to the EPG.
If the matrix is not built properly, there will be issues when switching from channel to channel,
or will have missing channels.
DiSEqC 2.0 allows for two way communication between receivers, switches and LNBF's for better diagnostics.
Thanks for the detailed answer; learned something. Before just knew that it checked if your satellites were aimed properly as Iceberg said.
