This post is going to look like several post that I've been watching over the past couple of months. I probably have the same problem (New and inexperienced), but I've been fooling around enough with it to finally ask:
I have a Fortec Classic Lifetime Receiver, Universal LNB, and a 36" dish. I thought that I would start out by trying to align to just one satellite. I chose IA5 and finally found it, but my signal fluctuates between 0 and 28 percent. I can't seem to get it any higher. I wonder if I really do have the right satellite? I have an orange bar which is what is supposed to indicate a quality signal. The signal isn't stable either - It constantly jumps around. I set everything back to factory defaults, just in case I had changed some critical setting. Are there any satellites close to IA5 which might throw me off?
I've adjusted everything to everywhere, and moved my skew around as well. I have a clear view to the satellite. Nothing seems to make it better.
Another thing that I don't understand....The level bar sometimes seems to lock up on 0 percent in the antenna setup screen. I use the bar on the screen where you choose the type of motor drive instead. Is this the right thing to do?
Would anyone be able to tell me the first steps to correct my problems?
Thanks!
Thanks!
