Weak Signal CTV HD (293)?
rdehaven
SatelliteGuys Guru
131
6
So. Cal
I haven't been able to get CTV HD for a few days now. Is anyone else seeing a weaker signal than usual? I'm getting all of my other channels just fine.
Using *C and a 75e in So CA. I see from the system status that this in RightVert. But I haven't been able to tell what transponder that CTVHD is using so I can look at othr channels on that transponder.
Probably the alignment on your elliptical 2-satellite antenna.
Is the dB reading lower on Anik F1R channels than F2??
Compare F1R channel 354 versus F2 channel 712.
HD channels 265 and 293 were moved to Anik F1R, so if your alignment is lacking
(not as strong on F1R) that would be your problem.
I am getting 293 with no issues in Rancho Mirage. You are probably not getting peak signal; there really is not much room for error.
*C picture?
4100 bell receiver
