Receiver reception from 61.5 was coming in intermittent and finally quit all together. When I went outside and unscrewed the line from the dish entering the DP34 switch, water came out of the connector. I left the cable end disconnected and pointed straight down. Water continued to drip out for a long time, leading me to believe that water was not only in the connector, but also in the cable. The inside of the connector is corroded. Techs are coming out Friday to fix. Other than running a new line from the dish to the switch, is there anything else I should insist on the tech checking/fixing? Also, what should I do to prevent water intrusion in the future? Thanks.
Steve
Steve
