Well we got the 10' BUD mounted on the building, and I have been able to identify and watch the following satellites with some of the stronger TP's.
Galaxy 15 - had 4 or 5 jewelry/Christian TP's that I could pull in. The picutre was not quite perfect, but very watchable.
Galaxy 14 - was able to lock on to several VCII TP's but had no authorization.
Echostar 9/Intelsat Americas 13 Jewelry Channel
Galaxy 4R - couple of Christian channels and identiefied a feed.
Intelsat Americas 6 - locked onto 3 different Xtsy VCII channels but could not view because of no authorization.
Was able to lock onto an ABC Channel East of IA6, but could not identify the Satellite.
I could tell there were more signals, but never got a picture moving East from IA6.
It just seemed like I was a little out of phase.
Maybe I don't have the Polar mount turned to true North which is keeping me from all the other Sats and signals. Just don't know what might be the cause.
I am hoping some of you might be able to give me some direction.
This is the equipment:
10' Winegard alum. mesh BUD.
Chaparell CoRotor II Plus with a Cal-Amp 25K C-Band Lnb, and an Aspen Eagle .6 KU LNB. I did pick up a couple of KU TP's in the above Sats with Von Weise 24" actuator and Drake ESR-1524 receiver.
I did have a question about the actuator too. It will almost lay down on the horizon when pointing West, but only come down about 1/3 of the way from center when pointing East, and won't go any further. The receiver tells me that it has reached the limit.
I walked through the setup part and moved the dish as far as possible both to the West and East, but I think it came up agains hardware limits in the motor.
Is that about all I can expect to the east out of this actuator?
Any pointers or help you guys can give me, I will be grateful. I would have never gotten this far without reading this site from one end to the other.
Thanks in advance,
Linuxman
Thanks in advance,
Linuxman
