Warning 004
Any body know what this warning is caused by? Only on my 722k, and only on sirius music station.
Here's what it says in the 722k owner's manual:
003, 004
The wrong type of coaxial cable may
be used in the system, or the cable
run length may be too long. There
may also be a problem with the
multi-dish switch.
• Make sure the system uses RG-6 coaxial cable; if not, call
your dealer or installer.
• Check the dish-to-receiver cable run length. If your system is
DISH Pro, it can be as much as 200 feet. If it is a Legacy
system, it should not be more than 100 feet. Check the coaxial
cables and their connections to and from the multi-dish switch.
Make sure that all required cables are in place, and check that
all cable connections are tight and dry (for outdoor cables). If
this does not work, do the Check Switch test.;)
HD satellites ?
Spotbeam 2 & 3 in Northern NH.
