wanted: dual lnbf with mount for 3 abn dish
iceturkee
DINFOS Trained Killer
7,392
146
daytona beach
just ordered the dish but need the dual lnbf. anyone have one for sale? looking to turn into glorystar system. thanks. PM me if you have one you want to sell.
I'm confused as to what you're looking for
Are you looking for a dual LNB (LNB with 2 outputs) or the LNB and holder? The dish usually has the LNB holder with it
looking for the dual lnb and the holder. sorry, for the confusion. please correct me if i'm wrong but doesn't the holder usually supplied on the dish usually only hold one lnb?
The holder holds one lnbf, but lnbf's come in single (one output) and twin (two outputs), some people call them dual's.
Edit: This is what a single looks like:
http://www.sadoun.com/Sat/Products/S/KUL1-Sadoun-Standard-LNBF.htm
This is what a twin/dual looks like:
http://www.sadoun.com/Sat/Products/S/KUL2-Sadoun-Standard-Dual-LNBF.htm
This is a monoblock single for 2 sats @ 4 degrees apart:
http://www.sadoun.com/Sat/Products/S/KLB1-Sadoun-Monoblock-Single-LNBF.htm
This is a monoblock twin/dual for 2 sats @ 4 degrees apart:
http://www.sadoun.com/Sat/Products/S/KLB2-Sadoun-Monoblock-Dual-LNBF.htm
This is a holder for an lnbf:
http://www.sadoun.com/Sat/Products/S/LNBHolder1.htm
This is an holder for 3 lnbf's:
http://www.gosatellite.com/3-LNBF-Holder-p/3-lnbf-bracket.htm
This is a holder for 4 lnbf's:
http://www.gosatellite.com/4-LNBF-Holder-p/4-lnbf-bracket.htm
Hope this helps....!!
KUL1  0.4db Noise figure Sadoun Standard Linear Offset LNBF LNB
KUL2 Dual Output 0.4db Noise figure Sadoun Standard Linear Offset LNBF LNB
KLB1  0.4db Sadoun Monoblock Linear Offset LNBF LNB
KLB2  0.4db Sadoun Monoblock Dual Linear Offset LNBF LNB
LNBHolder1 40mm KU-band LNBF Holder for Offset Dishes
3 LNBF Holder
4 LNBF Holder
what i need is best represented by the monoblock twin/dual for 2 sats at 4 degrees apart. hope that helps clarify what i'm looking for. thanks.
Oh the 2 LNB holder for the Glorystar system?
Like the 2nd pic here
http://www.satelliteguys.us/glorystar-support-forum/93282-glorystar-dual-lnb-upgrade-kit.html
Glorystar sells the kit with the holder and 2 LNB's
yep. but i'm wondering if anyone here has something used, that would work, that they don't need and would like to sell. fortunately, i have been able to piece this together between buying a used receiver and getting a great deal on a dish. when you're on a fixed income, gotta do what you can, the best you can.
