Thanks to our friends at SatelliteAV we are running another contest where you can win a brand new QUALITY LNB/F, please check below for all the details and specs : )
Here is the deal.........Show us a Picture (or two) of your setup/install or dish farm (post below, no pictures in the posts please add your pictures as attachments)
Brian will pick the Best picture and will send the lucky winner/s one of the below LNB/F.
The contest will run until the end of the year and the winner will be picked on the 3rd of January 2005.
Thanks again to Adventistsat and to our leader Scott for letting us run these contests. Stay tuned for even more give aways and contests here at the FASTEST growing FTA/MPEG-2 forum on the internet!
Invacom SNH-031
Universal Single LNBF 0.3dB
Featuring an ultra low noise figure of 0.3dB improving reception quality where signal is limited.
Each LNBF is shipped with the graphed results of the individual tests performed on each LNBF before leaving the factory.
Specifications:
Input frequency
Low Band 10.7 - 11.7 GHz
High Band 11.7 - 12.75 GHz
Output Frequency
Low Band 950 - 1950 MHz
High Band 1100 - 2150 MHz
Noise Figure 0.3dB typ
Gain 50 - 60 dB
Gain Ripple
26MHz bandwidth <+/- 0.5 dB
Low Band <5 dB typ
High Band <5 dB typ
Local Oscillator Frequency
Low 9.75 GHz
High 10.6 GHz
Local Oscillator Phase Noise typ
1kHz -65 dBc/Hz
10kHz -95 dBc/Hz
100kHz -110 dBc/Hz
Local Oscillator Stability
(including Setting, aging and +/-1 MHz typ temp. drift) +/-2 MHz max
Current Consumption 185mA typ
Image Rejection >40 dB
Isolation
Cross polar isolation >20 dB
High to low band isolation >25 dB
Two tone 3rd order intercept point (output) >15 dBm
Output Connector Female f type
Impedance 75 Ohm
Return Loss >10 dB
Operating temperature -40 °C to 70°C
Storage temp range -40 °C to 70°C
Power Supply 13 - 17v
(Picture 2)
Invacom SNF-031
Universal Single LNB 0.3dB
Simply the Best!
P120 flange mount. Perfect for replacing aging high noise Primestar LNBFs.
Complete install kit with o-ring and bolts.
Specifications:
Input frequency
Output Frequency
Gain 50 - 60 dB
Gain Ripple
Low Band <5 dB typ
High Band <5 dB typ
Low 9.75 GHz
High 10.6 GHz
1kHz -65 dBc/Hz
10kHz -95 dBc/Hz
100kHz -110 dBc/Hz
temperature drift) +/-2 MHz max
Isolation
Impedance 75 Ohm
Return Loss > 10 dB
(Picture 1)
"Please include what LNB/F you would like to win"
