Just another follow-up question to my plumb question from the other day...
When mounting the dish to the STAB HH90 Motor and then while securing the bracket onto the to the 1 5/8" diameter tube (it's the UnivMount II Universal Dish Roof/Wall Mount from Sadoun.com), I've noticed that the tube has sort of gotten bent (in other words, if you looked straight down from the top of the tube, you'd see that it's a little bent). The bracket is level once secured to the tube, however.
Is this common that the tube bends in a little when attaching the bracket to it and should this cause any signal problems? Would using a Dish Network or Directv tube work (are they the same diameter or is that irrelevant)? Any suggestions?
