[VOOM] VOOM Box and Changing Channels in DVI Problem
G
greatermac
Guest
I have a 30" LCD TV hooked up to the Voom box through DVI. Every time
I change a channel, it looses sync (colors turn weird, negative-like).
The TV manufacturer tells me this is a known problem with Motorola
boxes, since they use non-standard DVI. He also tells me that Motorola
can fix this through software, so I should talk to Voom. Is this correct?
I have a Panasonic LCD and had this same problem. Everything turned blue after switching from an HD channel to a SD. The TV has a color correction option and I turned it on and that fixed the problem.
Ooooo I'd love to hear the answer to this as I have the exact same
problem. I assumed it was the TV...
sbh
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> ________________________________
> Yahoo! Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/VOOM/
> To unsubscribe from this group, send an email to:
> VOOM-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> sbh
Is this only a problem when you have the voom STB set to native? I
recently switched from 1080i to native, and notice now that the picture
flickers a bit more when switching from one station to another if the
resolutions are different.
I'm using a DVI to HDMI cable.
/Sean
Native? Hmmm... I'm using 720p (it actually looks better on my
little 27" Olevia LCD that's having the problem). Using DVI-DVI
cable. If I turn the TV off then back on, everything's fine. But it
gets to be a pain if I'm channel surfing. Fortunately, the big plasma
works great! I may try native, tho, just to see what happens. The
other option is to see what happens with the component connection.
sbh
> > sbh
> correct?
> /Sean
> Yahoo! Groups Links
[VOOM] Re: VOOM Box and Changing Channels in DVI Problem
It looses sync on both 1080i and 720p (which is what looks best on
both my plasma and the LCD). If I go down to 480i, it changes channels
fine, without loosing sync (but 480i is really not an option). It does
work with component in, although I notice slightly better blacks with
DVI, so I would like to be able to use it).
As I said, I was told this is a known problem with Moto boxes, because
of their use of "non-standard" DVI. I already had the LCD monitor
exchanged, and still have exacly the same problem, so I am inclined to
believe this.
When I called Voom, they suggested that it may be the box, and will
exchange it. Hope this will fix it.
I read somewhere that the latest VOOM software upgrade fixed this
problem, but obviously not in my case.
Anyone with more insight?
Otherwise, VOOM rocks:)
> sbh
> > > sbh
> > > On Mon, 17 Jan 2005 19:00:27 -0000, greatermac <macman747@y...>
Every time
negative-like).
Motorola
Motorola
> > correct?
> > /Sean
> > Yahoo! Groups Links
Re: [VOOM] Re: VOOM Box and Changing Channels in DVI Problem
what software version do you have?
> believe this.
> > Native?=A0 Hmmm...=A0 I'm using 720p (it actually looks better on my
> > little 27" Olevia LCD that's having the problem).=A0 Using DVI-DVI
> > cable.=A0 If I turn the TV off then back on, everything's fine.=A0 But=
=20
> it
> > gets to be a pain if I'm channel surfing.=A0 Fortunately, the big=20
> plasma
> > works great!=A0 I may try native, tho, just to see what happens.=A0 Th=
e
> > sbh
> > > > Ooooo=A0 I'd love to hear the answer to this as I have the exact=20
> same
> > > > problem.=A0 I assumed it was the TV...
> > > > sbh
> > > wrote:
> > > >=A0 >
> > > >=A0 > I have a 30" LCD TV hooked up to the Voom box through DVI.
> Every time
> > > >=A0 > I change a channel, it looses sync (colors turn weird,
> negative-like).
> > > >=A0 > The TV manufacturer tells me this is a known problem with
> Motorola
> > > >=A0 > boxes, since they use non-standard DVI. He also tells me that
> Motorola
> > > >=A0 > can fix this through software, so I should talk to Voom. Is=20
> this
> > > correct?
> > > Is this only a problem when you have the voom STB set to native?=A0=
=20
> I
> picture
> > > flickers a bit more when switching from one station to another if=20
> the
> > > /Sean
> > > Yahoo! Groups Links
> > >=A0=A0
> > >=A0=A0
> > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of=20
> Service.
> Yahoo! Groups Links
> =95 To visit your group on the web, go to:
> =A0
> =95 To unsubscribe from this group, send an email to:
> =A0
> =95 Your use of Yahoo! Groups is subject to the Yahoo! Terms of=20
> Service.
>=20=20
[Non-text portions of this message have been removed]
2.40 (7.33), which is the latest and greatest, as far as I know. Are
many here using DVI out successfully?
>=20
>=20
channels
does
because
inclined to
> > believe this.
> > > cable. If I turn the TV off then back on, everything's fine. But=20
> > it
> > > gets to be a pain if I'm channel surfing. Fortunately, the big=20
> > plasma
> > > sbh
> > > > > Ooooo I'd love to hear the answer to this as I have the exact=20
> > same
> > > > > sbh
> > Every time
> > negative-like).
> > Motorola
that
> > Motorola
> > this
> > > > correct?
native?=20=20
> > I
> > picture
another if=20
> > the
> > > > /Sean
> > > > Yahoo! Groups Links
> > > >=20=20
> > > >=20=20
> > Service.
> > Yahoo! Groups Links
> >=20=20
> >=20=20
> > Service.
> >=20=20
>=20
I'm using DVI <-> HDMI on a Sony LCD rear projection with no problems.
I stated a day or two ago that since I switched the voom STB to native vs.
1080i, I get a bit more "flicker" when changing channels than I used to,
but it's not awful.
/Sean
I use the DVI and have for almost a year.. I have a DLP though.
Most complaints seem to be using LCD
--- In VOOM@yahoogroups.com, "greatermac" <macman747@y...> wrote:
>=20
>=20
> --- In VOOM@yahoogroups.com, Timothy Fouts <timothyfouts@m...>=20
> >=20
> >=20
> > > It looses sync on both 1080i and 720p (which is what looks=20
best on
> channels
> > > fine, without loosing sync (but 480i is really not an option).=20
It
> does
> > > work with component in, although I notice slightly better=20
blacks with
> because
> > > of their use of "non-standard" DVI. I already had the LCD=20
monitor
> inclined to
> > > believe this.
> > > When I called Voom, they suggested that it may be the box, and=20
will
> > > I read somewhere that the latest VOOM software upgrade fixed=20
this
> > > --- In VOOM@yahoogroups.com, Susan Hennessy <sbhnet@g...>=20
wrote:
> > > > Native? Hmmm... I'm using 720p (it actually looks better=20
on my
DVI
> > > > cable. If I turn the TV off then back on, everything's=20
fine. But=20
> > > it
> > > > gets to be a pain if I'm channel surfing. Fortunately, the=20
big=20
> > > plasma
> > > > works great! I may try native, tho, just to see what=20
happens. The
> > > > other option is to see what happens with the component=20
connection.
> > > > sbh
> > > > On Wed, 19 Jan 2005 10:41:57 -0500, Sean Butler <sean@2...>=20
> > > > > > Ooooo I'd love to hear the answer to this as I have the=20
exact=20
> > > same
> > > > > > sbh
> > > > > > On Mon, 17 Jan 2005 19:00:27 -0000, greatermac=20
<macman747@y...>
> > > > > wrote:
> > > > > > > I have a 30" LCD TV hooked up to the Voom box through=20
DVI.
> > > Every time
> > > negative-like).
> > > > > > > The TV manufacturer tells me this is a known problem=20
with
> > > Motorola
> > > > > > > boxes, since they use non-standard DVI. He also tells=20
me
> that
> > > Motorola
> > > > > > > can fix this through software, so I should talk to=20
Voom. Is=20
> > > this
> > > > > correct?
> native?=20=20
> > > I
> > > > > recently switched from 1080i to native, and notice now=20
that the
> > > picture
> another if=20
> > > the
> > > > > /Sean
> > > > > Yahoo! Groups Links
> > > > >=20=20
> > > > >=20=20
> > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms=20
of=20
> > > Service.
> > > Yahoo! Groups Links
> > >=20=20
> > >=20=20
> > > =95 Your use of Yahoo! Groups is subject to the Yahoo!=20
Terms of=20
> > > Service.
> > >=20=20
> >=20
VegasVoomer
This message was posted via http://www.satelliteguys.us by VegasVoomer
B
RE: [VOOM] Facts and Speculation
M
[VOOM] Help AVS
