This house I just moved into has a media cabinet inside the house, where the external signals (internet, cable, phone) go into to be split to different ports built into the walls around the house. The cable TV and cable internet are carried into the box via two separate cables. These cables run down under the house and outside to a box outside of the house. The local provider is Time-Warner, and this box is marked Time-Warner cable. We've got cable internet from them, but not cable TV.
A single black cable runs into this box. Right now, it is connected to one of the two cables running to the media cabinet. I'm assuming this is the internet connection. The other cable running to the media box is not connected. I'm assuming if we got cable from them, then they'd just hook the black cable to a splitter and then connect both media cabinet cables to the other end of the splitter.
Here's what I want to do. I still have my HD OTA antennae and HD satellite box from when I was with Voom. I want to use the antennae and box to just get me my local stations in digital HD. However, the connection isn't working properly.
If I wire the antennae directly to the Voom box, it works.
If I wire the antennae directly to the 8-way splitter the media cabinet and connect the Voom box to the cable outlet in the wall, it works.
However, if I run the antennae cable to the Time-Warner box and connect it to the other end of the unused cable that runs back to the media cabinet, it doesn't work.
The house is two years old, and the previous owners had both cable and internet, so I don't think there's a problem with the cable running from the Time-Warner box to the media cabinet.
There's also one other thing I've noticed. Both ends of the cables running from the media cabinet to the Time-Warner box have purple collars on the ends of them that are in the Time-Warner box. There are no collars in the media cabinet on any of the cables in there. Does this mean anything?
I've read here that purple cable is RG6 Quad. Does this mean I have to run the same type of cable from the antenna to the TWC box in order to get it to work?
