I'm using the old VOOM dish right now with my 811 HD Dish receiver. Before the recent changes in the HD pack I bought an 811 off someone on ebay and then connected a 110 lnb off of an old Directv dish....and the 61.5 from the VOOm dish. I connected it to a SW-21 switch and then to a combiner which combines my OTA ant and the two dishes. But, you can't combine a dishpro lnb with a legacy lnb (I think).wgolab said:Hey guys, does anyone know if its possible to use the old voom antenna and plug it into a new Dish Network reciever and get it to display the local HD channels?
Holy cow!!! I read your question wrong. I thought you were talikng about the dish for some reason. Yes it will work. Like SRueger said...you have to get a power injector or else you will get a zero sig.wgolab said:Hey guys, does anyone know if its possible to use the old voom antenna and plug it into a new Dish Network reciever and get it to display the local HD channels?
moviemax said:could someone send me a link for the power inserter or the poer injector needed to hook up the voom antenna to a dish network receiver. I have the vip 211 if that helps.
Can you tell me which power supply from fry's to get. The person I talked to didn't help much because he didn't understand. Do you need to have a certain info like (10db or 75OHM)?SKrueger said:I assume you mean the OTA antenna that Voom supplied. Works fine, that's what I'm using. The only thing you'll need to get is a power injector as this antenna requires a power supply. Readily available (about $20) at Fry's.
moviemax said:thanks for the links. can your tell me how to hook it up?
jekyll said:Can you tell me which power supply from fry's to get. The person I talked to didn't help much because he didn't understand. Do you need to have a certain info like (10db or 75OHM)?
Thanks in advance
Thanks but I found a wingard dealer in my town and they sell the PS-9370 for $18.SKrueger said:I can look at the model number when I get home. I found it right with the OTA antennas at my local Fry's. Its 110/120v in and 18v DC out.
