Hello everyone,
I just had Voom installed today and I ran into a few problems that I was hoping someone could help with:
1. I have a 4:3 screen and my InFocus is set to 4:3. With my old DTC 100, the aspect ratios were correct for both SD and HD. With the Voom box, the only way I can get 16:9 source material to display correctly is to change my X1's AR to 16:9, but then all 4:3 material appears squished vertically. If I leave the projector on 4:3, then the 4:3 material is displayed correctly, but the 16:9 material is stretched vertically. How can I set the Voom box to automatically correct the AR?
2. My channel giude is missing most, if not all of my OTA stations. Is there a "channel search" feature somewhere on the box?
3. None of the stations are showing any information in the guide to tell me what is playing, yet when I switch to the station, the movie (or show) is there. Any ideas how to fix it?
4. On my InFocus X1, if I feed the component output of the Voom box to the component/s-video input of the X1, the only mode that will display anything is 480i. If I take the same component output of the Voom box, feed it to a component to RGB transcoder, and then feed the RGB output of the transcoder to the RGB input of the X1, then I can use any of the resolutions. Is the component input of the X1 insufficient to handle anything greater than 480i?
Thanks...I am really looking forward to getting these bugs worked out.
