most of programing for the 211 is on 77 the programing is the same on both but I get a signal obstruction on 119 from time to time and the 211 will pick it up on 77 all but my localsWhat are you getting on the 211 from 77? What is the 922 missing for programming?
Keep in mind the OP shows that he lives in Mexico. 77 is the satellite of choice...
Do you have a dp 44switch or a dpp44 switch?I have a 2 dish setup 1.8m dish to get 110, 119 and a small dish for 77 and a dp44 switch just odd that the 211 works perfect and the 922 defaults back to 119. I will try the foil thing. I know if I disconnect 119 then yes it will go to 77. I also tried moving 77 to port 1 on the switch thinking maybe it used port position for priority but that made no difference. just trying to figure out how it decides which sat to look at. its not sq and not port. where the 211 looks to use sq
looking at the check switch page it says dpp44, I wonder if I put 77 on port 1 leave port 2 open and put 110 on 3 and 119 on 4 what I would getDo you have a dp 44switch or a dpp44 switch?
Did you try it?looking at the check switch page it says dpp44, I wonder if I put 77 on port 1 leave port 2 open and put 110 on 3 and 119 on 4 what I would get
