I am having an issue with my 2nd TV not getting a signal from my VIP722.
Problem started when I decided to try and add a coax between my remote antenna to extend the range. I also disconnected the coax from TV2 to a deplexer to shorten that cable run.
The 722 2nd tuner is still functioning because I can set, record and watch the DVR items from TV1. When I turn on my TV2 in the basement just white snow.
The original hookup utilized a diplexer between the dish and receiver. TV2 was directly hooked up to that diplexer too in the VHF/UHF connector of the diplexer. From that diplexer (in/out) it went up to deplexer 2 that fed into the separator and home distribution connection. The separator feeds into Sat1 and Sat2. All I see is white snow on TV2.
I have tried setting the modulator on air and cable to no avail.
I completely replaced the coax between the diplexer and TV2.
I removed the 2 diplexers from the system and just hooked TV2 directly to the Home distribution connection. Still white snow.
Is there any set order of tasks to set up TV2 that I am just not seeing?
Anybody have any ideas?
