On my old VIP622 I had it working so TV1 was controlled by both IR and UHF. The receiver was in single mode and I used HDMI splitters to split the output to different rooms.
The exact same way. You just need to set the remote addresses to the right number. If you already have the old remotes set the way you want then go to the system info screen (you can press the button on the front of the receiver or hit menu menu). Then hit record from each remote and it will set the receiver's remote address to the one in the remote already. You are good to go.
I'm having some trouble... for some reason when I press [RECORD] on my UHF remote (while in the system info screen) it doesn't update the remote address.
IR is working fine though.
On the UHF remote, I have the blue [2] chip facing up and UHF selected on the back. I tried changing the remote code (ie. hold [Sat] until all four lights blink, press 1-4 then [#]) and then pressed [REC] but it still didn't register on the receiver.
On my 722, I have a 5.3 IR for TV1, and I have a 21.0 in UHF mode for TV1 as well. I have the green #1 tab facing up. The 722 is in dual mode, with a second 21.0 controlling TV2.
You need to update remote # 1 address, not #2...making it uhf. To do this, in the sys info screen with the blue tab up and uhf selected under the battery cover, press the clear SAT button and than record - should change remote address for tv1
