VIP211 Internet Connection
Inside
66
A couple of questions
Does each receiver need it's own connection to my router or do the receivers talk to each other over the power line and only one receiver connected to the router?
Can the receivers connect by wireless, have read there might be a dongle available?
Thanks in advance.
Thanks in advance.
I used to have 3 ViP211 receivers. One was connected to the router via cat5 cable, and the others talked over the power lines to that one. Only one router connection was required, and no phone line. If there is a wireless solution for the ViP211, it must be relatively new.
There is a wireless solution if you have a wireless router. Currently only VIP Duo receivers (722,622,222) have software for it. If you have or get a slinglink adapter it will feed broadband through the electrical system to all VIP receivers. This requires one port on the router and that the slinglink and all receivers be plugged directly into the wall. To answer the other question, the receivers can communicate with each other, but can only share phone that way and not broadband.
Here are the instructions from Dish on using your electrical wiring to connect to broadband, they also show the other options.
Connect To Broadband - DISH Network
The 2nd example titled "Connect using a SlingLink connector" is what you want. After you connect your broadband to the outlet you need to unplug your receivers for 10 seconds.
Dish sells the Powerline Broadband Connector for $30 w/free shipping.
I can not post a direct link because you need to be logged in to find it,
Log into your Dish account->My Account->Order From Store-> Powerline Broadband Connector
Jordan
How Do I Sell My Old 522 Receivers ?
Hook Speakers To Dish Network
