VIP211 - Bum Switch? Bum LNB?
Shepherd777
17
Hello -
VIP211 - Latest Firmware - Dish 500 & 61.5 -
119 - 79
110 - 64
61.5 - 73
Every evening I get the "Aquring Satellite Signal" when I try to go to some channels.
Sometimes it is 119, sometimes 110, and others 61.5.
I go to "Installation Summary" and all 3 are Green and say "OK - Status - Reception Verified"
I hit cancel but it keeps going back to "Aquiring Sat Signal"
This day it was looking for 61.5. Signal would not lock (zero) when I first looked. I ran a "Check Switch" and the signal strength went uo to 50 and locked.
Then the screen went to: "Attention - Aquiring Satellite Signal" and ran thru steps 1-5.
Then it downloaded the Program Guide and everything is fine again.
Is there something wrong with my switch or LNB where a "Check Switch" function fixes the problem temporarily???
I'm sure it could be several things.
You may also want to supply the type of switch and/or LNBF you have (DP Plus Twin ?), which is available at the Check Switch screen; and maybe someone will have more info.
In the meantime, I suggest you turn off your receiver, then unplug it from the wall, remove the cable from the Sat-In connection on the back of the receiver; then plug the power back in without the satellite in cable; and then run a check switch. Of course it shouldn't find your Switch and/or LNBF.
After, turn off, remove power, plug in satellite in cable on back of receiver; plug in power; turn on; and run another check switch. Hopefully it will solve your problem.
Sometimes, just turning off and then unplugging the power for a few minutes will also work; but the above step accomplishes both removing the power and clearing the switch matrix.
Missing HISTORY button on DVR page
No more Pocketdish?
