Hi all,
About a week ago, my sister complained that her 222k receiver started acting up. It constantly give her a message that signal is lost and to call support on multiple channels. I just had a opportunity to drop by and check it out today.
Her setup:
Dish 1000+ with a DPP44 switch.
1 VIP 211 connected to output 1 on the DPP4 with a power inserter
1 VIP 222k connected to output 2 on the DPP4 (2 diplexers to combine cable modem)
The 211 has no issue and can see all the satellites and get all the appropriate channels.
Troubleshooting done so far:
1. Reset VIP 222k (unplug & replug back)
2. Ran check switch which went from 1 thru 50 on tuner1. tuner2 stay 1 of 1
- It only see 119 sat on 1st slot for both turner1 & turner2. 118, 110 & 129 is not detected
- For the switch type, it show nothing in turner1 and DP on turner2
3. Tested using my own 222k.
- Same exact result.
4. Move the connection from output2 to output3 on the DPP44
- Same result
5. Remove 1 diplexer at the DPP44 (I believe I connected it to output2)
- Successfully detected all 4 satellites
6. Replace the diplexer with a new one at the DPP44
- Problem occurs again
7. Remove new diplexer at the DPP44
- Problem still there
8. Remove the diplexer at the 222k (so no diplexers in between the switch and the receiver)
9. Put both diplexers back and connected to output3
- Same result
I'm thinking it either is a bad DPP44 (but only on output 2 thru 4) or a problem with the line between the DPP44 and the 222k. The only thing I haven't try it to move the 222k to output1 with the power inserter.
Any suggestions? Thanks.
Her setup:
- Same result
- Same result
