Hi guys....
I have been trying over the last few weeks to set up my Viewsat with a motorized dish.
I have a question regarding the sat setup in the Viewsat. It may be hard to explain.
I have been adding sats manually as I go (if it is not in the list) and blind scanning one by one.
I started at 72W and had success up to the sats in the 90's. Last night I attempted to add 93.1W. After the sat is setup in the menu, it asks you to save as it would normally. When saved you can go to the previous screen to scan. Once scanned, you can go to the sat list and call up the channels on that sat.
For some reason it is not saving the sat info, but the channels are there. Problem is, when you call up the sat list, it is blank. But again, the channels that were just scanned are there.
Because it is not saving the sat info, it wont move the dish over to that spot.
I tried another sat, 101W, and the same thing happened. Channels are there, but no sat info, no dish movement.
The dish moves fine if I call up the previous sats, 72, 74, 79, and so on....
Does anyone know if there is a limit to sats for the Viewsat?
