I've been lurking around here for a while but this is my first post. Sorry if this is a repeat of past info. I have read through several posts on this issue but I would like to validate that I am thinking correctly. I am one of those with the 61.5/110/119 setups looking to get to Eastern Arc or some setup to get all HD available. I am in Central NY on America's Everything pack with HD. Hardware is Dish500 (110/119) Dish 300 (61.5), DP44 switch, VIP722 and two older SD receivers (DVR310D and a 2700). To upgrade to EA I will have to get Dish out here to replace the dish and replace the two older receivers. Until I replace other TVs in the house I really don't want to replace the older receivers. I own all equipment.
I have an old 300 dish with a legacy LNB in the Garage. I know the the LNB would not work but I am thinking I could get a DP single LNB, mount this dish (or get a Dish 500 with "I" adapter and single DP LNB) and point it at 72.7. connect it the the remaining port on the DP44 and I will have 61.5/72.7/110/119. I believe this setup is one that a Dish tech would install but It would work, Correct? I read in one thread a statement that there may be possible future hardware issues with this Multi-arc setup. What would that be? What I am asking here is for validation that this setup would work and that there are no technical or ethical reasons that that I should not set this up.
