need more info
I have a mercury star receiver and I am thinking of purchasing the power tech v 3000 to move the dish.
My motor and polarizer are hard wired and it looks like the v3000 would take care of this very good.
If I am correct how would the mercury be connected to the dish mover? Please make it simple so I can understand and let me know if I am going the wrong way and what I should do instead of going this way.
thanks
There didn't seem to be enough info to give you a very good answer.
I took a look back through some of your previous posts to see what equipment you had and what you might be up to.
I get the impression you have a big dish (BUD) and a 4DTV receiver.
Normally, it would control your dish-mover and polarotor.
A Fortec Star Mercury II receiver along with a V3000 would certainly run the motor and move the dish.
Unfortunately, there is no way to control the polarotor on your LNB with the Mercury.
There are a couple of good FTA receivers which will handle the polortor if that is your need.
Likewise, the LNB could be changed out for one of the newer voltage-controlled models.
The old-timers won't recommend that approach, citing better stability in 20 year old technology than some of the new stuff.
That argument has two sides, and we can discuss both.
I believe the best thing would be to describe what you had in mind, in general.
What do you have that you want to keep?
What do you want to decommission?
Has anything failed or broken?
Has your interest changed?
