I had an odd thing happen this morning with my V-Box 7 and was wondering if anyone would know why this happened, so I can keep it from happening again. I wanted to find out what the actual space was that my 9' C-band dish took up within it's full range of movement so I moved the dish all the way to one side with the V-Box remote, then moved it to centered, then all the way back to the other side.
When I went back inside, when I selected a channel on the receiver the V-Box would go straight to 000 on all sats instead of the positions programmed for them.
I moved to a few sats and then hit store for the positions and they worked fine but are now at different numbers on the V-Box. Before I'd had 000 as center of the arc on the V-Box and now it's at like 1400 or so. The dish didn't move on the pole, the gears didn't slip on the mount, I have all that stuff marked and it's the same as before and I had limits set in the V-Box for just before both ends of the dish's travel range.
I've moved the dish all the way from one side and then back to the other again before and never had it do this, don't understand what caused it.
The dish is the 9' Radio Shack with HH mount and V-Box 7, one 4x1 diseqc switch going to the C dish and my Ku dish. The receiver is an X-2, but all the settings and everything seemed to be fine in that. The Ku dish still worked fine, using USALS for that, diseqc 1.2 for the C dish. Maybe reed switch or whatever in the motor on the C dish?
