Too much info just strains my brain... Following some very helpful links that elocs posted in the Help Desk forum, I found myself in a state of confusion. I'm trying to figure out exactly what my next installer will need to know and do to get it right the first time. Here's how I got confused...hope someone can straighten me out...
Most of the OTA stations I am interested in getting show a compass setting of 184.8 to 186.2. NBC at 185.1 is the channel I most want to insure good reception on, so if my antenna pointed pretty much at 185.5 (splitting the difference of the range of settings) would that work?
All the channels I want to receive are within about 45 miles according to both http://www.2150.com/broadcast/default.asp and http://www.antennaweb.com although the compass settings as well as mileage figures differ slightly between them, with antennaweb ranging from 184 to 185 on compass settings.
I found this link http://tiger.census.gov/cgi-bin/mapbrowse-tbl and used it to zero in on my city by zip code, then moved the marker to my exact location, to determine my exact latitude and longitude, rather than using the generic one for my city as well as to double check Magnetic Declination. (But unless you live in a pretty mountainous area, I doubt the exact latitude and longitude are really necessary.)
I came up with the same Magnetic Declination calculations on this link http://www.2150.com/broadcast/default.asp (using both exact and generic coordinates and putting in longitude as a negative number as instructed), leaving the Magnetic Declination space blank. It calculated a Magnetic Declination of 14.56 (no direction indicated and not negative). Using this site http://www.ngdc.noaa.gov/seg/geomag/jsp/struts/calcDeclination to calculate Declination, it shows 14.56 E (not negative either, but does include a direction).
Does that mean I subtract that number even though neither are shown as negative, since I am in the West? That's what I gathered the following link intends.
With my coordinates, this link for azimuth angles http://www.csgnetwork.com/antennasatelazposcalc.html calculated an azimuth angle of 110.0 and elevation of 14.7 for Rainbow1 at 61.5, or 118.3 azimuth and 22.5 elevation for AMC6 at 72 (if things go that way down the road).
So is the idea to deduct the elevation number from the azimuth number to get the exact angle for my location?
Is the number described as “elevation” the same thing as the number for “Magnetic Declination” above? The numbers are very close for Rainbow1 (but not for AMC6) from both calculator sites.
If they are not the same, do I deduct the Magnetic Declination from the azimuth after I deduct the elevation?
Is there a special tool for determining the final result for the azimuth angle, or is it just a matter of setting that number on a compass reading from magnetic north?
Can anyone help me get straightened out...or am I too far gone?? Vicki
P.S.: I could be worse, I guess...I haven't even started the cocktail hour yet!!
