Recently I decided to experiment with the DPP Twin, DP Twin, and the DPP 44 switch. I peaked in a Dish 500 with a DPP Twin and ran 1 line directly to a 510 receiver and just before the Satellite in port, I put a two way ATRAS splitter. Out of the ATRAS splitter, I ran a line to the Satellite in on the 510 receiver. I ran a check switch and everything came in. I sat and watched the signal strength for about 10 minutes, it stayed constant 125 on 119 and 105 on 110. I then ran a line for 61.5 to the additional port on the DPP Twin and ran a check switch. Everything came in fine. I decided to replace the DPP Twin with a regular DP Twin and everything came in fine again.
Another experiment with a different setup, a SD 105 with a 61.5 and a DPP 44 switch. The line running to the 510 from the DPP 44 switch, I used the ATRAS splitter and ran a line out of it to the Satellite in on the 510 receiver. Everything worked fine.
Can anyone explain why everything worked fine with a splitter at the Satellite in? Everyone has always said you can't split satellite signal. Know I know for a fact you can split one satellite signal (dual LNB...119,110, or 61.5), but more than one?
Is this just a temporary thing and the splitter will burn out or what? Maybe it depends on the type of splitter? Any input will be appreciated!!!!!
