Using different dish than one supplied by BEV
jessykanc
17
I believe that my low signal strength reception of 82W is going to require a larger dish - I was thinking about a 30". Anything worth doing, is worth overdoing :)
Can anyone recommend a 30" dish that receives BEV 82W signals? If not,
does anyone know of any tutorials or information sources on how to match a dish to a satellite, or is it basically trial and error?
Thanks, Jessi
Thanks, Jessi
The LNB is more important than the dish. Look for a dish that comes with a Dish Network or Echostar LNB.
A bigger dish will help a little with signal but mostly for rain fade. You can use a 30” dish. I use to when I had EVu….
Any 30” dish would work fine. You have to customize the LNB but ti can be done
Thanks, Jessi
I believe I would purchase an lnb with a noise level at .3 instead of .6 as most are .6 standard. That should also help you tweak 82W, imo.
That's the one I was thinking of. I actually posted that in hopes that someone might mention another one :)
And quite frankly, I would love someone to report the difference in signal strength it makes on 82 vs a .6 lnb as I have been very curious for several months now.
If I did not have a toroidal reverse reflector, I would have already tried it.
Help with SC HD Subscription
can anyone comment on the quality of the *C DSR530?
