I have attached a sketch of the layout for better understanding, if you see something wrong with the configuration please alert me.
I need help making a determination on this newly purchased WSI DMX242.
When using the WSI DMX242 dual output C-LNB with any 22KHz switch, either 'Ecoda', 'no name' brand and 'Chieta', the "on/22KHz" port is dead. No signal of either SS or QS is registered on the receiver signal meter for the "on/22KHz" port, I tested with 3 different receivers with the same results. Even if I eliminate the other brand LNB, the "on/22KHz" port of the 22KHz switch is still dead.
If I connect only the DMX242 to the "off" port and eliminate the other LNB, signals will pass through the "off" port but whenever both LNB's are connected, the "on/22KHz" port is dead. If I remove the DMX242 from the circuit, everything works well even with 2 LNB's of the other brand, this indicates the switches are working.
Does this mean that the DMX242 is defective or is it characteristic of this dual output type LNB not to work with 22KHz switches?
Thanks Guys
Thanks Guys
