Using a combiner with a switch?
iafirebuff
4,394
8
Waterloo, Iowa
Is there any problem using a signal combiner with a multi dish set up that is using a Diseqc switch? I would like to combine an OTA antenna feed with the single cable that is running into my house. I wold be combining the OTA signal with the signal from my FTA Dish, that has multi satellites coming from it. Any issues? Thanks in advance!
I have a multi-lnbs 4X1 DiSEqC switch output + digital cable into a "combiner" and run a single coax inside my house. The same "combiner" reversible decombine in 2 coax. It works well.
I'd have a sub-question... what if I decide to put a motor, will it works?
yes you can use one. You would need it diplexed between the diseqc switch and receiver
I have one to run StarChoice into the computer room with my multisiwtch (G4/G10/SBS6/Nimiq1)
CaptiveWorks 600 Premium & SG2100
Pansat 3500--time for a reset?
