D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/29/2008 1:41pm - 42 changes
Uplink Comparison Range: 07/29/2008 12:02A - 07/29/2008 01:01P
Channel Additions:
100 - HOME [173] added to Echostar6 72.7W TP 21 ConUS beam (A)
166 - CMT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
239 - WGN [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)(Chicago, IL)
322 - SHOEX [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
341 - ENCRW [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
345 - EDRAM [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
346 - ELOVE [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
456 - SPORT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
457 - SPORT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
494 - REAL [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
495 - PENT [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
496 - XTSY [MPEG4 SD] added to Echostar6 72.7W TP 21 ConUS beam (NA)
19007 - VOD [174] added to Echostar6 72.7W TP 21 ConUS beam (A)
19206 - OLYMP [DATA] added to EchoStar7 119W TP 13 ConUS beam (A) (H)
36862 - EEPG [EPG] added to Echostar6 72.7W TP 21 ConUS beam (A)
Channel Removals:
533 - PPV (A) removed from EchoStar1 148W TP 09 ConUS beam
533 - PPV (A) removed from Echostar12 61.5W TP 23 ConUS beam
573 - FPCHN (A) (H) removed from EchoStar1 148W TP 29 ConUS beam
573 - FPCHN (A) (H) removed from EchoStar3 61.5W TP 31 ConUS beam
580 - INFO (A) removed from EchoStar1 148W TP 09 ConUS beam
580 - INFO (A) removed from Echostar12 61.5W TP 23 ConUS beam
5992 - TEMP2 (NA) removed from Echostar12 61.5W TP 23 ConUS beam
Channel Moves:
105 - USA [MPEG2 SD] moved from EchoStar7 119W TP 02 ConUS beam to EchoStar7 119W TP 13 ConUS beam (A)
127 - OXYGN [MPEG2 SD] moved from EchoStar7 119W TP 17 ConUS beam to EchoStar7 119W TP 13 ConUS beam (A)
327 - TMC-E [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 02 ConUS beam (A)
328 - TMCXE [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A)
410 - ALTUD [MPEG2 SD] moved from EchoStar7 119W TP 13 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A) (H)
472 - SPORT [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
578 - BRDGS [MPEG2 SD] moved from EchoStar3 61.5W TP 18 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
622 - APUNJ [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
623 - ZGUJ [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
702 - GLBL1 [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 08 ConUS beam (A) (H)
703 - ISMOV [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A) (H)
778 - NBN [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
902 - GEONW [MPEG2 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 27 ConUS beam (A) (H)
998 - SMART [MPEG2 SD] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
5961 - SMART [DATA] moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
9405 - PNTGN [MPEG2 SD] moved from EchoStar3 61.5W TP 27 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
9418 - PAEC [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
9621 - BTV [SD TV] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 18 ConUS beam (A)
9902 - D61.5 [FTA] moved from EchoStar3 61.5W TP 14 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A)
9996 - ECC [MPEG2 SD] moved from Echostar12 61.5W TP 23 ConUS beam to EchoStar3 61.5W TP 10 ConUS beam (A) (H)
Channels in the system: 5053
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
