I currently have 4 receivers in my house, all of them SD. Three are D10s and one R16-300 DVR. The dish is an older round one labeled KTI. It has two cables coming off of it that attach to a 3x8 multiswitch. I would like to upgrade the DVR with a HD DVR, and one of the standard receivers with a HD receiver. Eventually I'd like them all to be HD but for now those two are the only important ones. I think I understand the basics of what all is required for this upgrade, but I was wondering if you could help me figure it out.
So I'll need a slimline dish. Since I don't need international channels I would get a 3 lnb over the 5. As far as SWM, if I want the D10s to still work I'd need the lnb with 4 cables which connect to a SWM8 multiswitch with legacy ports. If I get a SWM lnb with only one cable then the D10s will no longer be able to be used and I'd have to upgrade to newer receivers. Is that correct?
I'd also need a SWM splitter to make runs to the 4 receivers and one power inserter. Now does it matter which receiver the power inserter is connected to? Looking at Directv's website, the HD DVR I'd get is a HR24 and for the HD receiver a H25. Do these require a deca or anything like that? I don't plan on connecting ethernet to any receiver.
I'm going to talk to Directv and see what they say, but generally would I be better off buying and installing the dish other equipment myself before ordering a HD box, or is it cheaper to let Directv install it all?
Thanks for the help and clarifications.
