OK...There's C-Band which runs on frequencies between 3.7-4.2 MHZ
KU band has 3 bands, low, high & DBS
Low band is from 10.7-11.7MHZ and uses V & H polarity
High Band is from 11.7-12.2 and uses V & H polarity
DBS is from 12.2-12.75 and uses circular polarity
Most KU LNB's can get only the HIGH band stuff, which is what we mostly use in the US
The LOW band can be picked up with a Universal KU band LNB (Invacom as an example). This will get you both low & high. Europe is big with these. Only thing in US that can get it is PAS9 for Cubavision
DBS is for Dish/DirecTv
The issue is DTV LA (Directv latin america) uses the low band for KU but also uses Circular polarity. So you would need a DBS LNB that can do low band (DirecTV & Dish LNB's for the US cannot do low band)
