Uniden UST4400-Super Setup-Help!
Xilf
8
I have a Uniden UST4400-Super, and I'm trying to re-connect it, because I want to view wild feeds again.
However, I'm running into some trouble. I've got 2 big wires (red/white), I know white goes to negative, and red goes to positive. Then there is a green and an orange wires. Green = SEN, and orange = GRND. Then I have two small wires (one just silver bare cable, and one brown) both are way too short to try to connect anything. Then on a seperate cable I have 3 small wires....white, red, and black... Black = grnd, white = Pulse, and red = DC 6V.
Thats how I have it setup. But when I try to move the dish I get "Warning: DISH LIMIT".
Can't move the dish at all. I'm stuck on F4 and all I can view is QVC and HSN :( .
Any ideas on how I can fix this?
You probably have to go into the recievers setup menus and program in the east and west limits. Unfortunately I dont have one of those receivers so i am unable to tell you how to set that up.
I went into the menu's and I only see a way to program satellites, and not west/east limits. Also I already have a lot of sat's still programmed, so I think it would've also kept the limits too.
I think it's an issue on how I hooked up those cables.
Where does the brown cable, and the bare wire get connected to?
On my setup i have two spare wires also, the bare gound wire and another wire that was not used. Some position sensors use only 2 wires, some use 3.
Usually if there is a problem in the cabling one of a couple of things happens:
1)if the actuator wires are backward when dish is told to move east it will move west and visa versa
2) if position sensor wires are backwards you will get a "NP" or No Pulse error
btw i just found a copy of the owners manual for that IRD here:
http://uniden.custhelp.com/cgi-bin/uniden.cfg/php/enduser/fattach_get.php?p_sid=k3DmUHJh&p_tbl=9&p_id=981&p_created=1107543942&p_olh=0
setting dish limits is described on page 11 of the manual.
Hope this helps :-)
Now my dish will only move from G5 to F1 (C1). I want to move more towards T6 and sats around that area for the analog wild-feeds :) .
Question
What sat? NASA C band tran 18 passed 127 W
