Nice condition! No "backup" battery needed, (holds memory) 100 channel scanner and 20-channel AM/FM memory.
External speaker jack, terminals for AM antenna (loop AM antenna included.) Also includes adapter from BNC to "f"
to connect to standard UHF/VHF antenna for better reception. S.A.M.E. encoding and Weather ALERT, too! This one's got many features and is highly rated! $70 plus priority (or your choice of carrier) shipping of 3.5 lbs in continental U.S. PM with Zip code for total and/or more info!
<tbody>
</tbody>
(And yes, it's funny that this goes "on" just after another scanner sells....Been thinking of doing this awhile. I don't use this much, even at work in the radio station! It needs a good home...and was going to put here last week, but wondered if it would have an audience. Hope it does!)
FREQUENCY RANGE | |
Amateur Band (10 Meters) | 29.0- 29.7 MHz |
VHF Low Band | 29.7- 50.0 MHz |
Amateur Band (6 Meters) | 50.0- 54.0 MHz |
Aircraft Band | 108-137 MHz |
Military Land Mobile | 137-144 MHz |
Amateur Band (2 Meters) | 144-148 MHz |
VHF High Band | 148-174 MHz |
Federal Government | 406-420 MHz |
Amateur Band (70 cm) | 420-450 MHz |
UHF Standard Band | 450-470 MHz |
UHF T Band | 470-512 MHz |
800 Band | 806-956 MHz [Less cellular] |
AM Broadcast Band | 520-1720 kHz |
FM Broadcast Band | 88-108 MHz |
<tbody>
</tbody>
