under eave mount?
hotshot12345 said:
What about the universal eave mount and then attach a J-pole to it? It says only for DBS dish but should be OK for 36" FTA dish too right?
VMP DBS Gable Mount (GEM-1) from Solid Signal
I wouldn't hang a 36" on a single rafter tail. This bracket is too lightweight and also provides no lateral support. It would not provide adequate support and your dish would dance like a kite in the wind and ultimately damage or weaken the eave.
36" dishes have quite the wind load. I would have a two if not a three point mount when mounting under the eave. A rafter often needs additional blocking to add the necessary rigidity to support these larger dishes.
Adventures in Satellite Hunting.....30°W
Invacom qph-031 Lnb (Problem)
